parisperez4
Mar 11, 2016Aspirant
Unable to set up @ircard779s
I cant set up its not allowing me i also try with my provider they couldnt help
- I activate the netgear fuse wifi hotspot with my provider they couldn't help me
- parisperez4AspirantI activate the netgear fuse wifi hotspot with my provider they couldn't help me
- DarrenMSr. NETGEAR Moderator
Hello parisperez4
What issues are you running into when setting up the Fuse.
DarrenM
- MrXmasAspirantI'I'm having a problem installing network adapter drivers for the AirCard 779s. NETGEAR WWAN Modem and NETGEAR WWAN Device drivers intalled, but the NETGEAR WWAN Network Adapter won't install. I received a message stating that "Windows found driver software for your device but encountered an error while attempting to install it. — A device attached to the system is not functioning.
Windows 7 Professional, 64bit
