DanielN
Jul 13, 2017Aspirant
Unite Explore 815S DHCP not working
I'm having a problem today where DHCP is not assigning IP addresses and DHCP is turned on. I have this problem after doing a reset on the device or doing a reset from http://192.168.1.1. I connect ...
DanielN
Sep 12, 2017Aspirant
So it's been more than a month and a bunch of resets and still no DHCP coming from my Unite Explore. Static IP's set on my clients work fine through the Unite Explore, but it seems like the DHCP daemon on the device is not working. When I click on Wi-Fi then Devices and then the MAC address of my client device it states 0.0.0.0 for the IP address. I used a DCHPtest tool and there is no response from my Unite Explore for DHCP requests....
https://github.com/CyberShadow/dhcptest
However there is on my old Unite Pro... I totally believe this is a software issue because the fact that static IP's still works. Something is lasting through resets that prevents DHCP from working. Perhaps a full volume or something in the protected NVRAM.
DanielN
Oct 03, 2017Aspirant
I received an update last Friday from AT&T that fixed this issue. My firmware went from NTG9X40C_11.14.08.11 (2016/09/01) to NTG9X40C_11.14.08.28 (2017/08/24).
