Anonymous's avatar
Anonymous
Nov 07, 2023
Unlocking Telstra MR6500
Hi,
I have a Telstra locked MR6500 and would like to use an Optus SIM in it. How do I unlock the device to work with the Optus SIM?
  • michaelkenward's avatar
    michaelkenward
    Have you asked asked Telstra?
    Mobile operators are usually the ones that tie devices to their networks.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi @NTY1234
    If you would like to use your NETGEAR modem with a different service provider, you must obtain the NETGEAR AirCard modem’s MEP code from the service provider that sold you the NETGEAR AirCard modem.
    NETGEAR can't provide you with an MEP code.
    Blanca
    Community Team
