schiroggo's avatar
schiroggo
unstable wlan 785s
Hi there
I've got a problem with the wlan of my mobile hotspot.
My Computer and other devices loses the connection to the internet every few minutes.
After i disconnect and reconnect to the wlan, it works fine again.
The aircard is always in the same spot with a good lte connection( even an antenna is installed).
If I use my mobile as hotspot there are no problems.
Thanks for your help
1 Reply
