_Y_
Mar 22, 2018Aspirant
UPNP FOR NIGHT HAWK M1 MR1100
HELLO i have problem with upnp its not open to host a game the game arma3 i open the unpn in the router and port forward i noticed upnp only open in very old router or dsl viber router not th...
- Mar 29, 2018
Hi _Y_,
Thank you for the reply.
Can you try reseating the sim card and doing a factory reset on your M1. Next, let it boot all the way up and then search for update.
Please let me know if this works for you. :]
- Jason N
JasonN
Mar 28, 2018NETGEAR Employee Retired
Hi _Y_,
Please refer to the link below for your options. You are experiencing double NAT.
Use Port Forwarding
You have to set up port forwarding on both routers. On the M1, forward the port to the Nighthawk's WAN IP address. On the Nighthawk, forward the same port to the IP address of the device you want to access remotely.
Convert the Nighthawk to an Access Point
On the Nighthawk, go to ADVANCED > Advanced Setup > Wireless AP and enable AP Mode. This will disable the router, firewall and NAT functions on the Nighthawk. Your M1 will become the main router. This is the better option unless there is a specific security feature exclusive to the Nighthawk that you want to use.
Please let me know if this helps. :]
- Jason N
