_Y_'s avatar
_Y_
UPNP FOR NIGHT HAWK M1 MR1100
HELLO i have problem with upnp  its not open to host a game  the game arma3  i open the unpn in the router and port forward i noticed upnp only open in very old router or dsl viber router not th...
  • JasonN's avatar
    JasonN
    Mar 29, 2018
    Hi _Y_,
    Thank you for the reply.
    Can you try reseating the sim card and doing a factory reset on your M1. Next, let it boot all the way up and then search for update.
    Please let me know if this works for you. :]
    - Jason N
