_Y_
Mar 22, 2018Aspirant
UPNP FOR NIGHT HAWK M1 MR1100
HELLO i have problem with upnp its not open to host a game the game arma3 i open the unpn in the router and port forward i noticed upnp only open in very old router or dsl viber router not th...
- Mar 29, 2018
Hi _Y_,
Thank you for the reply.
Can you try reseating the sim card and doing a factory reset on your M1. Next, let it boot all the way up and then search for update.
Please let me know if this works for you. :]
- Jason N
JasonN
Mar 29, 2018NETGEAR Employee Retired
Hi _Y_,
- Jason N
_Y_
Mar 30, 2018Aspirant
hello
sorry Jason
i give up it wont work now always reboot
i already did factory reset ones before and did it agine yesterday now reboot if i but the sim card and work normal without sim card it happened before i must wait 1 or 2 day to start m1 normal
i go back now to 790s
i will search for another mobile router alcatel or tp link
i thought it will be ez but it not
thanks for your time.
