Cronos115's avatar
Cronos115
Follower
Nov 29, 2021
USB Wifi Adapter can't install genie
Trying to setup my Wifi adapter but i dont have a cd drive and i tried installing the programs that it told me to but im using a macbook air to do the setup and i cant extract the .zip or turn it into anything, would be a big help thanks in advance
  • plemans's avatar
    When I look up the system requirements for that adapter, it only shows as compatible with Windows 7/8/10/XP/Vista.
    Not Mac.
  • michaelkenward's avatar
    michaelkenward
    Many questions are common to lots of devices but in this case your USB adapter is nothing like the "Mobile Routers, Hotspots & Modems" covered in this section.
    plemans has already answered your question, but if you need more help, try the appropriate section for your hardware. That's probably here:
    WiFi Adapters - NETGEAR Communities
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
