sidprice
Jun 30, 2025Follower
Using MR6500 with Unifi Express Router
I just purchased an MR6500 and I need some pointers of how to set it up to work with my current network. My router is a Unifi Express device and presently it connects to a DSL modem. I want to r...
jamestea455
Jul 08, 2025Aspirant
You can set the MR6500 to bridge mode or IP passthrough, so it acts like a modem and passes the connection to your Unifi Express router. Then, connect the MR6500’s LAN port to the router’s WAN/Internet port. Make sure to disable DHCP on the MR6500 if needed. Check the admin interface for these settings.
