sidprice
Jun 30, 2025Follower
Using MR6500 with Unifi Express Router
I just purchased an MR6500 and I need some pointers of how to set it up to work with my current network. My router is a Unifi Express device and presently it connects to a DSL modem. I want to r...
AlberthaGreen
Jul 23, 2025Aspirant
To set up your MR6500 to replace the DSL modem and work with your Unifi Express router, first insert a SIM card into the MR6500 and ensure it has a good LTE signal. Then, access the MR6500’s admin interface (usually via its IP address in a browser) and disable DHCP if your router handles IP assignments. Set the MR6500 to operate in bridge or passthrough mode if available—this allows it to pass the public IP directly to your Unifi router.
