Todd6941
Mar 14, 2019Follower
Verizon AC791L Jetpack
I have a AC791L Jetpack from Verizon and there is an “Alert” that will not clear. I log into the admin site and the alert states that the SMS memory is full. I go to check my messages and there ore “n...
- Mar 17, 2019
Hi Todd6941
Welcome to NETGEAR Community!
Factory reset should clear all memory on the AC791L Jetpack. We suggest that you call Verizon to check if they have something saved for your line on their end. Can you also check if there is a firmware update available?
Blanca
Community Team
Blanca_O
Mar 17, 2019NETGEAR Employee Retired
Hi Todd6941
Blanca
Community Team
