Jimdandy1956's avatar
Jimdandy1956
verizon netgear ac791l 3G Speed test
What kind of speed can I expect from verizon netgear ac791l at 3G Speed test.  They throttle down from 4G LTE after 10gb to 3G. Thanks for your help.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Jimdandy1956
    The speed is up to how good your connection is in the area.
    DarrenM
    • Jimdandy1956's avatar
      Jimdandy1956
      Thanks for your response, but I was asking about relative speed reduction between 4G LTE & 3G... if they had the same connection level... what is the reduction percentage between to two?
