vmarie
Oct 01, 2020Tutor
What is MYSIMPLELINK connected to my Router?
I have an unknown device showing in my Genie that is called MYSIMPLELINK and I would like to know if I should block it and if so, HOW? I have tried to block it, but it is still showing up.
SOLVED: MYSIMPLELINK tends to be wifi cameras or doorbells. Add additional Router Security with NETGEAR Armor -Editor
Actully please disregard my last comment. I got NordVPN to work with ReadyNas 516.
I followed this guide. If anyone is interested have them follow the link below.
http://support.nordvpn.com/#/
path/1182453582 Thank you so much for your help. Finally got it work
do you have any wifi camera's, video doorbells, etc?
- NagejaInitiateIf you see mysimplelink on your WiFi it's part of the Ring video doorbell system but it's actually the Wireless Chime. So you should have the Video Doorbell and The Wireless Chime in the WiFi list.
You can go into the Ring app and go to device health and it will give you the MAC address and use that to identify which device is what.
Then label it in you router.
The Doorbell I put - Ring Video Doorbell.
The Chime I put - Ring Video Doorbell Chime.
Always remember to cross check MAC addresses.
Enjoy
