kgor93's avatar
kgor93
Initiate
Nov 16, 2017
What is the AT entercnd password?
You can connect via "telnet 192.168.1.1 5510" to gain access to "AT shell" which responds to various AT commands, e.g. status or band selection.
"at!entercnd" is the command for band selection but it needs a password. What is the password? It's not any of the common ones it usually is.
    • kgor93's avatar
      kgor93
      Initiate
      No this isn't it. Again, this is for the MR1100 Nighthawk, not the 77xS / 34xU
    • Tauroka's avatar
      Tauroka
      Guide
      Hi,
      I see from that reference it says the password is stored in NVRAM.
      Could someone with a modem that has a known password, complete the following steps:
      1. backup the NVRAM (xqcn format)
      2A. AT!ENTERCND="oldpassword"
      2B. AT!SETCND="password"
      3. backup the NVRAM (xqcn format)
      4. compare the xqcn files
      5. identify the NV_Items EFS_Data stream that changed, e.g.
      <Storage Name='EFS_Data'>
      <Stream Name="00000001" Length="8" Value="04 00 00 00 00 00 00 00 "/>
       6. identify the NV_Items EFS_Dir that has the matching stream
      <Storage Name='NV_Items'>
      <Storage Name='EFS_Dir'>
      <Stream Name="00000001" Length="28" Value="2F 6E 76 2F 69 74 65 6D 5F 66 69 6C 65 73 2F 72 66 6E 76 2F 30 30 30 32 35 32 31 34 "/>
       7. Report back here the EFS_Data for both passwords, both passwords and the EFS_Dir.
      Please note there will also be EFS_Dir and EFS_Data under EFS_Backup in the xml so don't mix them up.
      Once we know the EFS_Dir and password encoding, we'll know where to look for users with modems that have unknown passwords.
    • JSchnee21's avatar
      JSchnee21
      Virtuoso
      Hi Guys,
      How to backup the NVRAM?  Export config from the admin webpage or something else?
      Thx,
      Jonathan
  • the password that worked for me
    “lindeman”
    I used it with :
    AT!ENTERCND=“lindeman”
    • sale7n's avatar
      sale7n
      Forgot to say
      I’m at 10.12 firmware version
      i think the password just work for this firmware
      and the reason l’m still with this version because I can’t update my router as it’s known issue.
      I’m waiting for the update that coming later this month
    • spamcoll's avatar
      spamcoll
      Tutor
      Hi,
      Do you know entercnd password for at&t version of MR1100?
  • Please Help,i cant find AT!ENTERCND for AC790s-1Z1MES
