DaForc3's avatar
DaForc3
Follower
Jul 01, 2017
When are we getting NEW firmware for the Nighthawk M1?
The M1 is currently suffering from...
Wireless stops responding
Random reboots
Battery sometimes refuses to charge
Ethernet going to sleep
Constant issues with usage meter
Poor upload performance
Lack of advanced settings in menu (Qos)
Hurry up Netgear!
  • Hi  Wiz_THS,
    The current implementation on 10.16.04.04 (MR1) is as follows:
    - MR1100 boots up and ethernet port is live for about 30 seconds
    - If Ethernet port detects something plugged in it will remain active
    - If Ethernet port detects nothing is plugged in it will disable the port to preserve battery life
    We are investigating ways of keeping the ethernet port active whilst still trying to preserve battery life.  These fixes could possibly be implemented in MR2 but not commited as yet.
    Kind Regards,
    ArodiD
  • +++++1
    The ethernet timeout and no IP-passthrough are show-stoppers for me. I can't use this device for my requirements until this is fixed - it's sitting on the shelf......
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    We plan to fix the following issues in the next firmware update which is scheduled for release late July/ early Aug depending on Telstra certification.
    Random reboots
    DarrenM
    • Wiz_THS's avatar
      Wiz_THS
      Any updates as to when the firmware update for fixing the 'Ethernet going to sleep' will be released?
      • MicW's avatar
        MicW
        Luminary
        Apparently a new firmware came out yesterday. Though there is no information anywhere on what issues it addresses. You could try a manual check under Administration in settings and see if ti will update
