RLBJR
Dec 20, 2024Follower
Where can I get a book on the M6 Pro Mobile Router. Model Number MR6500
Where can I get an instruction manual for MR6500, M6 Pro mobile router. It will not connect to my iPhone so I do not have a hotspot that I can use for my iPhone. It keeps saying no connectivity.
Thank You
RLBJR
https://www.downloads.netgear.com/files/GDC/MR6500/MR6500_MR6110_UM_EN.pdf
You might check with the ISP if there's any specific settings/apn setup that is needed for connectivity.
It can help to look at things the right way round. "iPhone will not connect to MR6500".
Just another user with time on their hands.
