electricpurple
Jun 11, 2021Aspirant
Where is Guest network setup on an MR1100
The interface on my Nighthawk MR1100 does not have a guest setup option in the Settings dropdown like I see on youtube. Is there a frimware update that adds this or is there some other trick?
- Blanca_ONETGEAR Employee Retired
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
Guest WiFi feature is only enabled on AT&T SKU.
Similar Thread: Guest Network on MR1100 (Nighthawk M1)
Blanca
Community Team
- electricpurpleAspirant
Yes, mine is the MR1100-100NAS. if it is only the ATT version with a guest network then I will be returning mine to Amazon and going with a more robust Pepwave product. Thanks for yor assistance!!
The manual says nothing about AT&T only.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Select a WiFi Profile.
