DBZFanZero's avatar
DBZFanZero
Follower
Jun 28, 2016
Which Netgear USB router is compatible with Netgear Aircard 341U modem?
I have a Netgear(Sprint) 341U modem , and would like to add an ethernet router to distribute internet inside my home. Does a Netgear router support this ? I want to plug the USB modem into a USB router port and split the signal wired over ethernet. No wireless is needed.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello dvanmilligan
      You may want to look into the MBRN3000  it supports 3g modems.
      DarrenM
  • What Ive gathered from netgear support and community threads is that there is no officially supported router for this modem. The netgear nighthawk used to support it until a recent firmware update removed that feature... There are many routers that support 3G modems (cough Asus), I am looking for one that specifically supports this modem (driver compatibility).  I guess I have no reason to purchase a netgear router, had they continued to support the 341U Modem I would have paid any price..
