AlexinQLD's avatar
AlexinQLD
WIFI extension options for Nighthawk M2 router.
We live in rural Queensland and use a Netgear Nighthawk M2 router for WIFI access
We get poor cover coverage across the house and we would like to improve this?
We are considering two options:-
(1) Firstly, get an and plug it into the ethernet plug in the modem, or
(2) Buy a Nighthawk MK63 Mesh system
Any guidance would be appreciated
  • plemans's avatar
    I'd would get a router or mesh system and connect to it.
    The reason why is the why on hotspots/cell spots is limiting in how far the wifi can broadcast. Its part of its broadcast regulation since they're designed to travel.
    If you get a router/mesh system, it doesn't have that restriction. Plus they tend to have more cpu/processing power and be more capable.
    • AlexinQLD's avatar
      AlexinQLD
      Who you suggest buying either a Orbi or Google nest system?
      • plemans's avatar
        either. I haven't used any of the google products but I have the orbi's so that's all I can attest to.
        Dongknows has done some really good reviews on mesh systems and its worth taking a look at his site.
