full_wagon
Sep 21, 2021Aspirant
WIFI has been disabled after update on my ATT mr1100-2a1nas
Hi there ! After update to last firmware MR1100-100NAS_23113828_NTG9x50C_12.06.11.00_00_GenericNA_05.03 WIFI on my device is disabled. When I try configure it manually in web panel it doesn'...
Sep 22, 2021Guru - Experienced User
did you try factory resetting the device?
Thats usually the first thing I try if a firmware upgrade causes issues.
full_wagon
Sep 22, 2021Aspirant
Of course I try factory reset button on device - it is no effect. What about ip passthrough option?
- plemansSep 22, 2021Guru - Experienced User
I don't have that device to check. but maybe the IP option was pulled in the latest firmware.
Are you within warranty? You can open a support case with netgear.
Click on "mynetgear" at the top. register an account and the device. From there you can open a support case.
- full_wagonSep 22, 2021AspirantIt's great idea to open support case on netgear site, but I think it's unreal for me (maybe I'm wrong) cause I bought this device on ebay 'as is'.
I thought that I can fix it with my own and with community experience.
