Budgie348's avatar
Budgie348
will a NETGEAR Nighthawk 4G Router Mr2100 connect to a public wifi hotspot
will a
connect to a Public WIFI hotspot?
1 Reply
  • plemans's avatar
    Depends.
    If the wireless is open without any security or login info (such as terms/conditions), it has wifi offloading.
    but not 100% that'll work if there's any type of login/t&C.
    If not, you need something with wisp mode that supports that function.
