  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello tjkcc
    yes this will work just need a micro sim from a US carrier to use it or check with your current carrier if they have a international plan that works in the US.
    DarrenM
      • DarrenM's avatar
        DarrenM
        Hello Noumka
        If the Sim card you get for the AC785 is one of these bands it should work.
        2G 900/1800 MHz
        DarrenM
        • Dual Band Wifi 802.11n avec 2 SSIDs simultanés
        • LTE cat 4/HSPA+/EDGE/GSM
        • 4G LTE FDD 800/850/900/1800/2100/2600 MHz
        • 4G LTE TDD 2600 MHz
        • 3G 850/900/2100 MHz
