DrDunc
Mar 25, 2018Tutor
Windows XP drivers for Nighthawk LTE Mobile Hotspot Router Model MR1100
I'm attempting to help an elderly friend. Until recently he has been accessing the internet from his old Windows XP machine (for email only) via a Telstra supplied 4G Wifi router, plugged into a USB ...
- Apr 03, 2018
Hi DrDunc,
If the XP machine has an Ethernet NIC then you can plug in via Ethernet. Depending on the FW version you are on, you may need to tap the power button to wake up the Ethernet port. If you are plugged in via USB to PC then the Ethernet port shuts off until USB tethering is no longer happening.
If the XP machine does not have an Ethernet NIC, then try downloading and installing the drivers from the following link: http://www.downloads.netgear.com/files/aircard/AC790S_Zain/Driver%20package%204.3.0.0.exe
If you are still having issues then PM your contact details and we can work out a suitable time to troubleshoot whilst you are on-site.
Kind Regards,
ArodiD
DrDunc
Mar 26, 2018Tutor
Yep, that's the page I already found. His XP machine clearly indicates that it doesn't have a driver for this device - "The drivers for this device are not installed. (Code 28) To reinstall the drivers for this device, click Reinstall Driver." Clicking this button however fails to find a suitable driver locally and this is where we hit the problem of requiring internet access in order to fix the problem of not having internet access. Perhaps the required drivers are not specific to the MR1100 but are more generic, only they weren't part of the original XP or service packs. If so, perhaps someone knows of a locatin for drivers for this class of device?
schumaku
Mar 26, 2018Guru - Experienced User
Strongly doubt there is a driver required. This router does provide Internet access either as a wirelss access point to wireless clients or to systems connected over an Ethernet cable.
The features list of the marketing blush does clealry state "Simple setup with no software to install – just power on and connect".
The USB ports aren't used for Internet access, in my undertanding ie. the USB 3.0 port is to attach a storage device (disk/flash).
