sakiv
Aug 14, 2019Aspirant
10g fiber
Hi All, M4300 is connect with 10g sfp from fiber store SFP-10GLR-31 and on other end is netgear pro safe 3300-28x- poe+ with same sfp. There is no connection light blinking at all. If i chan...
- Aug 14, 2019
I have a setup with M4300 with modules from FS: Both 10GBASE-SR, -LRM (both multi mode fiber, the later for longer, old OM1/OM2 lines) and 10GBASE-BX (single mode bi-di) without any issues so far. You say that you have SFP-10GLR-31 modules from FS, so that looks like 10GBASE-LR modules which in turn require single mode fiber for a connection. Single mode fiber isually has yellow jacket - can you verify what type or jacket color your patch cable and what type of fiber your fiber in between is?
Also keep a lookt at the output of of "show logging buffered" and what "show fiber-ports optics all" throws at you. There are more subcommands in the "show fiber-ports" , also have a look at "show interfaces status (all)".
msi
Aug 14, 2019Luminary
sakiv
Aug 15, 2019Aspirant
Thanks Mate did check all the things in cli. Did notice that in prosafe its shared 10g in copper and fiber. i was already using 10g on copper so the fiber was not giving any connection light. change the setting of copper to 1g and bingoo.
