Galcomm's avatar
Galcomm
4300 Series Web and Cloud Management
Hi Everyone,
I have a number of these M4300 series switches (12x12F) that are being used for multiple functions including aggregation and distribution to small server farms. Whilst the supplied web interface is 'okay' - my colleague has just purchased some switches and wireless access points that are Netgear Insight cloud managed -- does anyone know how I could 'cloud' enable the 4300 switches please? or is it a future product release that I have to wait for?
Thx
Garth
  • Hi Galcomm
    Thank you for your question.
    M4300 switches aren't Insight / Cloud Managed for now. Instead, you can use NMS300 for monitoring purpose (and can use NMS300 web page from anywhere in your network).
    Never say never, maybe one day,  the M4300 switches will be cloud-based. But this not a committed feature in the roadmap at this point.
    I hope this helps!
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi Galcomm
    I hope this helps!
    • Galcomm's avatar
      Galcomm
      Many thanks for the quick reply - I will stick to using NMS.
      Thanks!
