spopuri's avatar
spopuri
ACL rules M4300
I would like to create extended ACL's to allow only DHCP and DNS from a subnet to a server.
  • Retired_Member's avatar
    Retired_Member
    May 08, 2020
    spopuri
    On Web GUI, when you create new rule for the IP ACL, only need input 4 fields as below, all other parameter just keep default config:
    Sequence Number: input any value is ok;
    Action: Permit
    Protocol Type: UDP
    Dst L4: input 53/67/68
    The ending deny everything rule is default behavior, no need config by manual.
    Then go to 'IP Binding Configuration' page, select the correct port that you want to apply this IP ACL rule.
ProSupport for Business
