spopuri
May 07, 2020Aspirant
ACL rules M4300
I would like to create extended ACL's to allow only DHCP and DNS from a subnet to a server.
- Retired_MemberMay 08, 2020
On Web GUI, when you create new rule for the IP ACL, only need input 4 fields as below, all other parameter just keep default config:
Sequence Number: input any value is ok;
Action: Permit
Protocol Type: UDP
Dst L4: input 53/67/68
The ending deny everything rule is default behavior, no need config by manual.
Then go to 'IP Binding Configuration' page, select the correct port that you want to apply this IP ACL rule.
Retired_Member
May 08, 2020Hi spopuri ,
Welcomet to Community!
Suggest you config IP ACL to meet your requirement.
As both DHCP and DNS is based on UDP protocol, so you can create one IP ACL with 3 rules(permit udp destination port 53/67/68). Then binding the IP ACL to the pyhsical port or VLAN.
For detailed ACL configuration, please refer to link (Software Administration Manual: Page 171)
Below is the example config:
ip access-list test
permit udp any any eq domain
permit udp any any eq 67
permit udp any any eq 68
exit
interface 1/0/1
ip access-group test in 1
exit
Hope it helps!
Eric
spopuri
May 08, 2020Aspirant
Thanks, Eric, I would like to do this in the web interface. Is it possible to give me an example?
Should I mention the port number in the source and destination
