spopuri
May 07, 2020Aspirant
ACL rules M4300
I would like to create extended ACL's to allow only DHCP and DNS from a subnet to a server.
- Retired_MemberMay 08, 2020
On Web GUI, when you create new rule for the IP ACL, only need input 4 fields as below, all other parameter just keep default config:
Sequence Number: input any value is ok;
Action: Permit
Protocol Type: UDP
Dst L4: input 53/67/68
The ending deny everything rule is default behavior, no need config by manual.
Then go to 'IP Binding Configuration' page, select the correct port that you want to apply this IP ACL rule.
spopuri
May 08, 2020Aspirant
Thanks, Eric, I would like to do this in the web interface. Is it possible to give me an example?
Should I mention the port number in the source and destination
LaurentMa
May 08, 2020NETGEAR Expert
Hi,
The examples for both CLI and Web GUI are in the Software Administration Manual starting page 172 (ACL chapter). That's Eric indicated the link to it.
https://www.netgear.com/support/product/m4300.aspx#docs
Specifically, http://www.downloads.netgear.com/files/GDC/M4300/M4300_SWA_EN.pdf
Unlike other manuals presenting all commands, the Software Administration Manual is a collection of real word examples with explained config.
I hope it will help you, please let us know how it goes
