Bonis
May 15, 2019Follower
After Upgrade of M4300-8x8f fans stop Working
After a firmware upgrade of M4300-8x8f from 12.0.2.17 to 12.0.7.12 all fans are not working:
FAN Status
Unit ID
1
2
3
4...
LaurentMa
Jul 22, 2019NETGEAR Expert
Hi,
In current firmware we have fixed the software. Bith GUI and CLI show correct OFF status when fans are shut down because ambiant temp is under 25C and the switch internal components are within spec.
Remains the amber light on the front. The LED amber color will be fixed in subsequent firmware.
I would advise you upgrade to the latest FW if you can bear with the amber FAN light.
maindriver
Jul 23, 2019Apprentice
Hi LaurentMa ,
Thanks for the swift reply.
Do you know if the firmware guys will be adding the option to force the fan on?
I don't like seeing these switches at 59 degrees when a 48 port PoE switch a few U beneath it is at 31 degrees.
