Bonis
May 15, 2019Follower
After Upgrade of M4300-8x8f fans stop Working
After a firmware upgrade of M4300-8x8f from 12.0.2.17 to 12.0.7.12 all fans are not working:
FAN Status
Unit ID
1
2
3
4...
kgpns
Jan 22, 2020Aspirant
M4300-8x8F. I upgraded to 12.0.9.3. Still have Amber Fans LED and Fans "Stopped" in Web Interface.
Has there been any progress on this issue? When will we have an option to leave the Fans "ON"?
- schumakuJan 23, 2020Guru - Experienced User
kgpns wrote:Has there been any progress on this issue? When will we have an option to leave the Fans "ON"?
Posted end of December 2019, just before your question:
LaurentMa wrote:..., we are working on a new setting in the configuration for selecting quiet mode or fan mode on demand. The ETA isn't firm at this stage but I'll come back to the Community to pre-announce it with a schedule. I would say three months by now, if it can help.
So we can stay tuned.
- jmsoren5Jun 11, 2020Aspirant
Upgraded today to 12.0.11.11. And the last post on this thread was over 4 months ago. The fans still do not start. The Temperature status on the System main page for me is: MAC, 56 degrees C, System, 58 degrees C. This is WAY too hot for electronics. And yet the fans do not turn on.
Looking for a resolution, PLEASE!
- LaurentMaJun 11, 2020NETGEAR Expert
Hi jmsoren5
Thank you for your message. Please find the solution here: https://community.netgear.com/t5/Managed-Switches/Feature-request-M4300-8X8F-Allow-force-fans-on-quiet-mode-or/m-p/1888995#M9657
With latest M4300 firmware on the M4300-8X8F (XSM4316S), a new command is present for forcing fan operation, or requesting quiet (fanless) operation when ambient temperature can sustain it.
To enable fans for perpetual fan operation:
User:admin
Password:************
(M4300-8X8F) >en(M4300-8X8F) #config
(M4300-8X8F) (Config)#no environment set fan quiet
(M4300-8X8F) (Config)#exit
(M4300-8X8F) #save
This operation may take a few minutes.
Management interfaces will not be available during this time.
Are you sure you want to save? (y/n) yConfig file 'startup-config' created successfully .
Configuration Saved!(M4300-8X8F) #
To disable fans for fanless operation when ambient temperature is under 25C:
User:admin
(M4300-8X8F) (Config)#environment set fan quiet
(M4300-8X8F) #save
Please let us know how it goes, many thanks!
