Bonis
May 15, 2019Follower
After Upgrade of M4300-8x8f fans stop Working
After a firmware upgrade of M4300-8x8f from 12.0.2.17 to 12.0.7.12 all fans are not working:
FAN Status
Unit ID
1
2
3
4...
LaurentMa
Jun 11, 2020NETGEAR Expert
Hi kgpns
I trust this works well, we QA'ed this a lot and I tested it personally too. It is only configurable through the command line, either local console or distant telnet/SSH.
I hope this helps,
I hope this helps,
jmsoren5
Jun 11, 2020Aspirant
Just ran the commands. Both Fan-1 and Fan-2 started immediately; the LED on the front of the switch went Green, and the Web GUI shows both fan status as OK.
Thank you very much. I understand the need for the feature given that this is a small, sometimes desktop, switch. But mine is in a noisy, very warm, computer room, so I want and need those fans to run!
