andrearp
Aug 21, 2017Follower
BPDU Guard, loop protection and more traffic management features on M4100
Hi, I'm having doubts regarding the BPDU Filtering and Guard feature on the Switch. CLI Manual provides just the commands, there's not much in the Software Admin Guide, which does explain some featur...
DaneA
Oct 04, 2017NETGEAR Employee Retired
Hi andrearp,
Welcome to the community! :)
I inquired about your concern and found out that a higher tier of NETGEAR Support was able to help you when you have contacted NETGEAR Support.
DaneA
NETGEAR Community Team
