PHF
Nov 21, 2024Aspirant
Cannot change Port speed
Hi, I have a S3300 switch with a SPF+ port which is currently active but which is set to no auto-negotiation, 100 Mbps, Full-duplex. The device connected to that port is capable of a higher speed...
schumaku
Nov 21, 2024Guru - Experienced User
Whatever make and model of SFP module you are talking of, depending on age and vendor, not all modules are workable (and supported) on switches.
PHF
I know that the SPF module is good. If I plug it into the second SPF+ port on the same switch it works at 1 Gbps, auto-negotiate, without any problems.
However, I need to have both SPF+ port in use at 1 Gbps on this particular switch.
It's changing the port settings which are causing the issues.
- schumakuNov 21, 2024Guru - Experienced User
Whtever, could be either the one SFP port being defect, or this specific probably configured to operate as stacking port insted to generic Ethernet mode?
- PHFNov 21, 2024Aspirant
The port is not set as a stacking port.
It was previously used for a device that would only run at 100 Mbps. That is why the port was configured that way originally.
Now I need to reset the port to auto-negotiate, but I'm unable to make any changes to the port configuration.
