jezolekuk
Apr 15, 2020Aspirant
Cant change ipv4 management vlan
Hi, Im having an issue trying to change ipv4 managment vlan from default 1 to 10. I have tried all sorts of options and their permutations - no luck. I keep getting an error message saying : "F...
- Retired_MemberApr 16, 2020
Welcome to Community!
It's because currently IP address is set on VLAN1, when you want to change VLAN ID from 1 to 10 on this page, it's mean will set same IP on VLAN 10 meanwhile. So it not allowed and will popup error message.
Please change IP address & Gateway to another subnet meanwhile, I think it will be success.
Hope it helps!
EricZ
Retired_Member
Apr 16, 2020
Hope it helps!
EricZ
- jezolekukApr 16, 2020Aspirant
You solution has worked.
Thanks
