paulmilsom
Jan 19, 2020Aspirant
carnt connect to fsm7352ps
i am having problems connecting to a fsm7352ps poe switch, its working as it should, poe etc just carnt access it to change settings etc - it doesnt get found when i use an ip sniffer either and carnt...
paulmilsom
Jan 31, 2020Aspirant
i now have the null cable and can connect through hyper terminal, but it doesnt give any options for factory reset?
DaneA
Feb 02, 2020NETGEAR Employee Retired
I apologize for the late response. :(
To perform a factory reset via the console, go to privileged EXEC mode and execute the command 'clear config.' As reference, read page 9-27 of the ProSafe 7300S Managed Switches CLI Manual Version 8.0 here.
DaneA
NETGEAR Community Team
