amaccabe
Sep 17, 2020Aspirant
Certificate/Letter of Volatility for XSM4316S
Good morning, I'm looking for a Certificate/Letter of Volatility for the XSM4316S managed switch. Thank you in advance, Andrew Maccabe
DaneA
Sep 17, 2020NETGEAR Employee Retired
Welcome to the community! :)
You may download the Letter of Volatility of the XSM4316S switch on this link. The link will expire within 2-3 days.
If you were able to download it and do not have any further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” on this forum thread so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
amaccabe
Sep 18, 2020Aspirant
Thank you!
A quick follow-up question: what is the "special software utility" the LOV mentions for the process to clear the non-volatile memory?
- schumakuSep 18, 2020Guru - Experienced User
Dou you intend to destroy the switch completely? Erasing the flash will make it inoperational forever. It won't start, boot, load firmware, allow any configuration, ...
- amaccabeSep 18, 2020Aspirant
No. The presumption is that one could re-load the original boot image into flash from an external source.
No whatever utility require then. You can flash whatever firmware image into both partitions, and do a factory reset.
I don't think there is a user-process allowing to flash the low level code and the boot image into an all empty flash.
