amaccabe
Sep 17, 2020Aspirant
Certificate/Letter of Volatility for XSM4316S
Good morning, I'm looking for a Certificate/Letter of Volatility for the XSM4316S managed switch. Thank you in advance, Andrew Maccabe
amaccabe
Sep 18, 2020Aspirant
Thank you!
A quick follow-up question: what is the "special software utility" the LOV mentions for the process to clear the non-volatile memory?
schumaku
Sep 18, 2020Guru - Experienced User
Dou you intend to destroy the switch completely? Erasing the flash will make it inoperational forever. It won't start, boot, load firmware, allow any configuration, ...
- amaccabeSep 18, 2020Aspirant
No. The presumption is that one could re-load the original boot image into flash from an external source.
- schumakuSep 18, 2020Guru - Experienced User
No whatever utility require then. You can flash whatever firmware image into both partitions, and do a factory reset.
I don't think there is a user-process allowing to flash the low level code and the boot image into an all empty flash.
