GaACETech
Dec 28, 2015Guide
Correct Switch - Ports - POE - Fiber
NETGEAR ProSAFE GS728T 24-Port Gigabit PoE Smart Managed Switch with 8 PoE+ Ports 192w (GS728TP-100NAS) My Needs: 16-24 ports at least 6 POE at least 2 Fiber Optic this will be used as cen...
JohnRo
Dec 29, 2015NETGEAR Employee Retired
Hello GaACETech,
Welcome to the community!
Based on your needs, it appears that it is a good model. It has 4 SFP ports for fiber connection, 24 PoE ports and also a gigabit switch. So I'll say this would fit your needs. As a central switch, will you do all the routing on this switch? Do you have a dedicated DHCP server or router connected to it?
Looking forward to your response.
Thanks,
