wiper1
Jun 15, 2023Initiate
CPU and memory load OID for GS324TP
Hi, I´m trying to monitor this switch through SNMP and I can´t find the OID for CPU and memory load. I´ve tried with all the MIBS from the download page with no luck. Does anybody know if it´s possi...
- Jun 15, 2023
Hi schumaku,
Thank you for the help!!
schumaku
Jun 15, 2023Guru - Experienced User
Considering there is neither high / variable CPU usage nor variable memory load - because this isn't a L3 routing device - it makes perfect sense there are no such OIDs available.
The CPU is mainly active to deal with the Web UI, collect SNMP data, or applying config changes.
wiper1
Hi schumaku,
