DetexCorp
May 27, 2024Aspirant
Error changing the subnet mask for VLAN IP address
I am trying to change the subnet mask of a VLAN IP address (Routing>VLAN>VLAN Routing Configuration). After changing the subnet mask and clicking apply, I get the error "failed to set IP Address". ...
DetexCorp
I don't have an Advanced option; see the attached image.
schumaku
May 27, 2024Guru - Experienced User
Somewhere the IP configuration of the switch must be visible, eg. System > Management > IP Configuration.
Either it's DHCP assigned or defined locally on the switch.
- DetexCorpMay 29, 2024Aspirant
I have that set up for the management interface; I am trying to change the subnet mask for the VLAN routing interfaces.
Thanks,
Keith
