Retired_Member
Aug 04, 2024GS108Ev3 fragmented IP packet dropping
Model: GS108Ev3 - 8-Port Gigabit Ethernet Smart Managed Plus Switch Firmware: V2.06.24EN I noticed that when I fragment a SYN packet in very small (e.g. 8 byte) fragments some of the packets [al...
schumaku
Aug 04, 2024Guru - Experienced User
You don't test the switch with your test, just the uC IP stack with your scenario.
The GS108Ev3 or essentially almost all Plus Switches do restrict the MTU only on the admin uC (very basic IP stack, no PathMTU discovery, no tagged frames for the admin WebUI or the Netgear Switch Discovery Protocol in use for the discovery and optionally for the ProSAFE Plus Utility [obsolete as EoL, only available for special purposes]), not in the data path.
-Kurt.
PS, Since the GS108Ev3 is (like any Netgear Plus or Smart Manged Switch models) not a Manged Switch, I'll request modertor to move your post to the more apprpopriate Plus and Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management.
Retired_Member
Aug 04, 2024Thanks for your reply but respectfully you missed the point completely.
- schumakuAug 04, 2024Guru - Experienced User
So this is a reason to close your account - because a rnandom community member hasn't undersood your report?
- Apr 12, 2023Retired_Member
