Retired_Member
May 08, 2019GS516T problem 802.3ad LAG/LACP - only one direction full bandwidth
Hi all
In reference to this post: https://community.netgear.com/t5/Managed-Switches/XS728T-problem-802-3ad-LAG-LACP-only-one-direction-full/m-p/1079353/highlight/true#M1786
I have the same problem with the GS516T that i‘ve buyed today.
Cisco supports those hashing configurations:
- src-mac — Source MAC addresses
- dst-mac — Destination MAC addresses
- src-dst-mac — Source and destination MAC addresses
- src-ip — Source IP addresses
- dst-ip — Destination IP addresses
- src-dst-ip — Source and destination IP addresses (Default)
- src-port — Source Layer 4 port
- dst-port — Destination Layer 4 port
- src-dst-port — Source and destination Layer 4 port
The described issue tells me, that Netgear only works with the destination MAC but normally you will need, at least, Source and destination MAC addresses to make LACP work bidirectionally.
What configuration options do i have? If none (as expected), does netgear release an updated firmware? If not; i wasted 300$ and can throw that switch into garbage.
Best regards
Tom
Best regards
Tom
- Retired_Member
Hi community,
After having a longer talk with the Netgear support;It's obvious that the switch only supports IEEE 802.3ad with destination MAC address hashing; so therefoe you/me/all only have unidirectional load balancing.Unforantetly there is no information about this limitation (or even possibilities) in the datasheet. Unfortunately there is no effort to fix/change this hardcoded behaviour within the firmware (they redirect me to the more expensive product lines of Netgear - so that is maybe a marketing descision not to support bi-directional load balancing). There is no possiblity that Netgear takes the switch back; so there is no money-back-guarantee.
Have a great day
Tom- schumakuGuru - Experienced User
Retired_Member wrote:
Cisco supports those hashing configurations:Cisco does offer Mac and MAC/IP up to the Cisco 550X Series Stackable Managed Switches class - that's the counterpart to Netgear's top-of-the-line stackable switches - and does leave any further details open, too:
I have the same problem with the GS516T that i‘ve buyed today.That would be an almost 20 year old switch - so a GS516TP probably.
What is the exact use and test case in your deployment?- schumakuGuru - Experienced User
Can't speak for the GS516TP (no such device here) - when pushing data from multiple systems [so different source MAC] to an IP address (QTS NAS here) served by a teo or more LACP LAGs operated on various similar switches like the mentioned XS728T/XS748T (v6.5.1.36) or an MS510TX (v6.7.0.37) we find the upload traffic flowing over multiple members of the port channel - so the impression is there is (at least) a src-dst-mac hash used.
