TDevSw
Nov 06, 2024Aspirant
GS716T v3 API
Hi,
I would like to do an automatic port test without accessing the web interface.
I would like to verify that it actually works by connecting two ports together.
I did a test with the web interface in the "Monitoring -> Cable Test" section, but I would need to automate this function with external software.
Does Netgear provide APIs for this model that I can use from C/C#/LabView?
Thank you
SNMP for example?
agent Cable Tester Status
1.3.6.1.4.1.4526.10.1.4.1
Status of the Virtual Cable Tester active(1) - cable testing is in progress. Set to this value to start the test. success(2) - A successful test was performed. Cannot be set. failure(3) - A failure was encountered during the test. Cannot be set. uninitialized(4) - No test has been performed yet. Cannot be set.agent Cable Tester If Index
1.3.6.1.4.1.4526.10.1.4.2
Determines on which port to perform the cable test. Limited to copper based ports.agent Cable Tester Cable Status
1.3.6.1.4.1.4526.10.1.4.3
Indicates the results of the Cable Test. normal(1) - The cable is working correctly. open(2) - The cable is disconnected or there is a faulty connector. short(3) - There is an electrical short in the cable. unknown(4) - No test has been performed yet, or a test is currently in progress.- TDevSwAspirant
Hi,
Thank you for the answare but I'm not very familiar with the SNMP protocol.
I downloaded from ezfive web site the "SnmpGet.exe" and "SnmpSet.exe" software tool for windows.
On my Netgear I added this user SNMP: 0.0.0.0 - 0.0.0.0 - public - ReadWrite - Enable (I use my neatgear switch on private network) (I tried also added private R/W community)
I launched these command:
C:\temp\SNMP\SnmpGet>SnmpGet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.3 -c:public
SnmpGet v1.01 - Copyright (C) 2009 SnmpSoft Company
[ More useful network tools on http://www.snmpsoft.com ]OID=.1.3.6.1.4.1.4526.10.1.4.3
Type=<Unknown>
Value=C:\temp\SNMP\SnmpGet>SnmpGet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.2 -c:public
[ More useful network tools on http://www.snmpsoft.com ]OID=.1.3.6.1.4.1.4526.10.1.4.2
Type=<Unknown>
Value=C:\temp\SNMP\SnmpGet>SnmpGet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.1 -c:public
[ More useful network tools on http://www.snmpsoft.com ]OID=.1.3.6.1.4.1.4526.10.1.4.1
Type=<Unknown>
Value=C:\temp\SNMP\SnmpGet>SnmpSet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.2 -val:1 -c:public
SnmpSet v1.01 - Copyright (C) 2009 SnmpSoft Company
[ More useful network tools on http://www.snmpsoft.com ]%Failed to set value to SNMP variable. Not Writable (notWritable(17))
Where I Wrong? Can you help me for laucnh a first command for understand the protocol?
Do you know a simple OID ofr verify the read and write commands?
Thank you
- TDevSwAspirant
Hi,
Type=<Unknown>
Type=<Unknown>
Type=<Unknown>
%Failed to set value to SNMP variable. Not Writable (notWritable(17))Where I Wrong? Can you help me for laucnh a first command for understand the protocol?
Thank you
- TDevSwAspirant
Hi,
Type=<Unknown>
Value=SnmpGet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.2 -c:public
Type=<Unknown>
Value=SnmpGet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.1 -c:public
Type=<Unknown>
Value=SnmpSet -r:192.168.0.239 -v:2c -o:1.3.6.1.4.1.4526.10.1.4.2 -val:1 -c:public
Thank you
