daievans
Aug 04, 2018Aspirant
GS724TP and a Hawkeye C7800 - more questions
I currently have these two devices functioning, with the Hawkeye being DHCP enabled and the DHCP disabled on the switch.
As i find the Genie software to be erratic, can i set up these two so that t...
JohnC_V
Aug 13, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
