sdillon
Aug 23, 2023Follower
GS752TPv2 -Does this support LLDP to put a VoIP phone into the voice vlan?
trying to setup a voice vlan and have the switch identify the voip phones in assign them to the voice vlan, do the netgear switches support this? If not is there a work around?
schumaku
Aug 24, 2023Guru - Experienced User
These switches are auto-assigning VLANs based on the OID, the vendor part of the device MAC address. Please consult the fine 24-Port and 48-Port Gigabit Ethernet PoE+ Smart Switches with 4 SFP Ports and Optional Remote/Cloud Management User Manual for Auto-VLANs based on OID, starting from p.137 ff. FMI.
