pp6000v2's avatar
pp6000v2
Follower
Dec 01, 2023
GS752TPv2 firmware failure, or hardware failure?
I picked up a used GS752TPv2 that was "tested, powers on."  That it does, but I get no connectivity on any ports.  I got into the serial console and logged what's happening.  With no connectivity, I can not tftp anything. I can send a binary over ymodem to it from the menu, but IDK what I need to do to either save it as one of the boot partitions, or what I need/could do.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.12.01 19:31:11 =~=~=~=~=~=~=~=~=~=~=~=
reset
BOOT Loader Version 1.0.0.5 (2017-12-28 09:35:22 UTC)
CPU  : 700 MHz
RAM  : 128 MB
FLASH: 32 MB
Model: GS752TPv2
MAC  : B0:39:56:BA:E9:FF
Hit Esc key to stop autoboot:  1  0
GS728_752TP_TPP# ?
?       - alias for 'help'
base    - print or set address offset
boota   - boota  - boot application image from one of dual images partition automatically
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
env     - environment handling commands
erase   - erase FLASH memory
flerase - Erase flash partition
flinfo  - print FLASH memory information
flshow  - Show flash partition layout
go      - start application at address 'addr'
help    - print command description/usage
iminfo  - print header information for application image
loadb   - load binary file over serial line (kermit mode)
loads   - load S-Record file over serial line
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
md      - memory display
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printsys- printsys - print system information variables
protect - enable or disable FLASH write protection
reset   - Perform RESET of the CPU
rtk     - rtk     - Realtek commands
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
savesys - savesys - save system information variables to persistent storage
setenv  - set environment variables
setsys  - setsys  - set system information variables
sf      - SPI flash sub-system
sleep   - delay execution for some time
tftpboot- boot image via network using TFTP protocol
tp      - Mass production TP
upgrade - Upgrade loader or runtime image
version - print monitor, compiler and linker version
GS728_752TP_TPP# reset
CPU  : 700 MHz
RAM  : 128 MB
FLASH: 32 MB
Model: GS752TPv2
## Booting image from partition ... 1
## Booting kernel from Legacy Image at 81000000 ...
   Version:      6.0.0.45
   Created:      2018-07-26  17:55:08 UTC
   Data Size:    7815870 Bytes = 7.5 MB
   Checksum ... OK
   Uncompressing ... OK
Starting kernel ...
dal_cypress_construct_phyConfig_init,1039: 0.16 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.17 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.18 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.19 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.20 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.21 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.22 phy enable fail.
dal_cypress_construct_phyConfig_init,1039: 0.23 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.16 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.17 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.18 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.19 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.20 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.21 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.22 phy enable fail.
dal_cypress_construct_phyConfig_init,1055: 0.23 phy enable fail.
unknown rt error code f00f
<3><!-RTK_INIT_FAILURE-!>Init SKI Core Driver Module....FAILED
<3><!-RTK_INIT_FAILURE-!>Init Switch STP Module....FAILED
do_init_module: 'l2g_stp'->init suspiciously returned 557, it should follow 0/-E convention
do_init_module: loading module anyway...
CPU: 0 PID: 116 Comm: insmod Tainted: P           O   3.18.24 #3
Stack : 00000000 00000000 00000000 00000000 809f4c3a 00000040 00000074 803a0000
	  8041d258 86ce1840 80352d18 8039ca67 00000074 809f3d84 8041d258 86ce1840
	  c13aef48 00000000 803a0000 802c64bc 00000006 8001a590 00000000 00000000
	  803559c4 86cedd00 00000000 00000000 00000000 00000000 00000000 00000000
	  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Call Trace:
[<80007dc8>] show_stack+0x84/0xa0
[<80061ac0>] load_module+0x1f04/0x22a8
[<80061f04>] SyS_init_module+0xa0/0x104
[<8000ac9c>] handle_sys+0x11c/0x140
CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 8003e298, ra == c00ebf64
Oops[#1]:
CPU: 0 PID: 132 Comm: insmod Tainted: P           O   3.18.24 #3
task: 86c6d568 ti: 86cee000 task.ti: 86cee000
$ 0   : 00000000 00000001 00000000 0000007d
$ 4   : 00000000 ffffffff 00000000 00000000
$ 8   : 0000003c 801524b4 ffffffff 803b3d0c
$12   : 810ba414 00000076 00000000 00000000
$16   : 00000001 00000000 00000000 00040000
$20   : 00000001 c1970000 c1970000 00000000
$24   : 8003e280 c00ebe70
$28   : 86cee000 86cef9b0 803a0000 c00ebf64
Hi    : 00000008
Lo    : 7c1f07c3
epc   : 8003e298 down_interruptible+0x18/0x60
ra    : c00ebf64 osal_sem_take+0xf4/0x158 [rtcore]
Status: 1000ff02	KERNEL EXL
Cause : 08800008
BadVA : 00000000
PrId  : 00019555 (MIPS 34Kc)
Modules linked in: l2g_igmp(PO+) l2g_lacp(PO) l2g_authmgr(PO) l2g_stp(PO) l2g_gvrp(PO) board(PO) ski(PO) osal(O) ksi(PO) net(PO) board_conf(O) max3421_hcd rtdrv rtk rtcore
Process insmod (pid: 132, threadinfo=86cee000, task=86c6d568, tls=77875460)
Stack : 810ba414 00000076 00000000 00000000 ffffffff c00ebf64 803a0000 00040000
	  00000001 c1970000 c1970000 c1300000 c00ebfc8 86cefa30 00040000 00000001
	  c1970000 c07a3070 803a0000 c14c0d1c 1000ff03 00000008 80152400 c1970000
	  803a0000 c14c0d2c 00000000 87c01640 00000020 810ba400 87c02380 00000000
Call Trace:
[<8003e298>] down_interruptible+0x18/0x60
[<c00ebf64>] osal_sem_take+0xf4/0x158 [rtcore]
[<c07a3070>] rsd_l3_adminIntfMgmt_get+0x34/0xa0 [ski]
[<c14c0d2c>] mcast_querier_init+0xf4/0x198 [l2g_igmp]
[<c14add84>] mcast_init+0x84/0x1a4 [l2g_igmp]
[<c1981038>] init_module+0x38/0x90 [l2g_igmp]
[<8000058c>] do_one_initcall+0xf8/0x25c
[<80061a88>] load_module+0x1ecc/0x22a8
Code: 41706000  32100001  000000c0 <8c820000> 1040000c  00000000  2442ffff  ac820000  00001021
---[ end trace 35a95f222340d0a4 ]---
Segmentation fault
<3><!-RTK_INIT_FAILURE-!>Init Switch LLDP Module....FAILED
do_init_module: 'l2g_lldp'->init suspiciously returned 557, it should follow 0/-E convention
CPU: 0 PID: 147 Comm: insmod Tainted: P      D    O   3.18.24 #3
Stack : 00000000 00000000 00000000 00000000 809f4c3a 00000040 00000093 803a0000
	  86c6d7b8 85873980 80352d18 8039ca67 00000093 809f3d84 86c6d7b8 85873980
	  c1a96838 00000000 803a0000 802c64bc 00000006 8001a590 00000000 00000000
	  803559c4 86cefd00 00000000 00000000 00000000 00000000 00000000 00000000
Call Trace:
<3><!-RTK_INIT_FAILURE-!>Init Switch Loop Detection Module....FAILED
insmod: can't insert '/lib/modules/3.18.24/extra/l2g_rldp.ko': Operation not permitted
Segmentation fault
Segmentation fault
/bin/sh: ?: not found
~ # ls
bin       home      linuxrc   mntusb    sbin      sys       var
dev       init      mnt       modsqfs   sqfs      tmp       webtmp
etc       lib       mntlog    proc      sqfs.img  usr
~ # ipcd bin
/bin # ls
ash            diag           klogd          nstat          snmpget
boa            dnsdomainname  ksid           openssl        snmpinform
bootklogd      echo           ln             ping           snmpset
busybox        false          ls             ping6          snmpwalk
cat            fpmd           lsmod          polld          stty
chmod          halt           mdev           poweroff       syslogd
chown          handler        mkdir          ps             telnetd
cli            hostname       mknod          pwd            timed
cp             ifconfig       modinfo        reboot         touch
cttyhack       inetd          modprobe       rm             true
date           init           mount          rmdir          umount
depmod         initd          mountfs        rmmod          uname
df             insmod         msntp          sccd           usaged
dhcp6c         ip             mv             sh             zebra
dhcpcd         kill           netstat        snmpd
/bin # ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default
    link/sit 0.0.0.0 brd 0.0.0.0
/bin # reset
No RepliesBe the first to reply
ProSupport for Business
