mcbenc
Sep 01, 2022Aspirant
Gs752txp - maximum supported voice device limit 64 is reached
Hi Netgear Community, Has anyone seen this log message before and if so, could you let me know how to increase or remove the limit if possible, or at least just confirm it’s a limitation of the hardw...
mcbenc
Hi Marc,
Many thanks for your response.
Yes, I believe auto-voice VLAN is being used.
Sorry, I forgot to mention that there are 2 switches in a stack. Would the same limitation apply? Do you know if this is documented at all?
Thanks, Ben
Thanks, Ben
