Fffrank
Apr 18, 2019Aspirant
GSM712 not recognizing Unifi AP.
This is an older gigabit switch but works fine for my needs. All the ports work and I've tested them with various devices. It also worked fine with my Unifi AP until recently when it just sort of w...
Fffrank
Tried another experiment. Connection links if I manually set port to 10 or 100. As soon as I set it to AUTO or 1000 it fails.
DaneA
Apr 21, 2019NETGEAR Employee Retired
Hi @Fffrank,
Thank you for your response. It seems that a compatibility issue happens between the GSM712 and the Unifi AP after the Unifi AP has been upgraded to the latest firmware. The GSM712 is already on the latest firmware. Have you tried to factory reset the GSM712 and check if the same problem will occur?
Be reminded that the GSM712 is already End of Life (EoL) and there won't be any new firmware release or future fixes for it since it has been discontinued years ago.
DaneA
NETGEAR Community Team
