vijaykhilnani
Nov 12, 2011Aspirant
GSM7328SV2 not able to uplink to GS724TPS
there is a GSM7328SV2 connected to GS724TPS The GSM7328SV2 is not able to ping to the GS724TPS reset to factory defaults the GSM7328SV2 and updated the firmware to 8.0.3.25 ( latest ) GSM7...
vijaykhilnani
Nov 15, 2011Aspirant
[QUOTE=vijaykhilnani;378457]I replaced the GS724TPS with another identical switch GS724TPS : problem persists
I replaced the GSM7328SV2 with another GSM7328SV2 : problem persists
I replaced the GS724TPS with a Linksys 10/100 mbps the network works
conclusion : the GSM7328SV2 does not ping to the GS724TPS but it uplinks
To the linksys 10/100
Will Netgear test this in their lab and confirm
is it something to do with the POE
