vijaykhilnani
Nov 12, 2011Aspirant
GSM7328SV2 not able to uplink to GS724TPS
there is a GSM7328SV2 connected to GS724TPS The GSM7328SV2 is not able to ping to the GS724TPS reset to factory defaults the GSM7328SV2 and updated the firmware to 8.0.3.25 ( latest ) GSM7...
vijaykhilnani
Nov 18, 2011Aspirant
Disabling Spanning Tree Protocol on the GS724TPS solves the communication problem
However every few hours the GS724TPS hangs
Power led and unit I'd led remain on but all port LEDs go off
Communication stops
Switching off and on does not bring up the switch
Port LEDs remain off after power cycle
Only way to start up is push a pin in the factory defaults
And go and disable STP all over again as factory default is STP enabled
Still waiting for Netgear to find a solution
Vijay Khilnani
computer Engineering
Communication stops
Vijay Khilnani
